2 way switch on stud wall (image included)
Ill have to check it again tomorrow to see. The next problem will be that I dont know which switch is the broken one. Sigh.
For some reason I still feel like it's something else and a new switch wont do anything
It sounds like a strapper is not working.
Could be a fracture inside the insulation.
Could be wired wrongly or not present.
Could be a faulty switch.
If it has always acted in this way to the best of your knowledge it could have been incorrect in the first place.
A conductor might be missing completely.
It needs testing and drawing out if you are capable of doing that safely.
A quick test will be to remove this brown and grey and link them together
which should light the lamps (without switches making any difference)
What will that prove?
errrrr... it's called faultfinding and a good first step to help talk a DIYer through the problem.
At the moment buying a switch has been suggested without knowing which switch - or for that matter even if - switch is faulty: the classic autofitter mentality of changing things willy nilly until something changes.
Even OP is not convinced.
