doitall said:A wing is shaped so that the airflow speeds up over its upper surface. This results in a lower static pressure above the wing than below it and so a lifting force is created.
I agree![]()
but ---
No air flow, plane go nowhere.
Although this is perfectly true, there WILL be airflow when the planes engines start pushing it forwards. Thats how planes work.![]()
Dont think this ones been posted here before.
this bloke due to the influence of G&T forgot one vital fact.it stands still and because it does not actually proceed in its static space neither does the air therefore no lift over the wings
The plane should take off because the wheels are free rolling and the rearward force of the conveyor is counteracted by the bearings in the wheels. It doesnt matter how fast the conveyor goes because the plane itself is not in contact with it.
if they had wheels on the flip side would they be able to take-off upside down?
mmmmm?
I have no intention of going through it all again ...
MW
well to be fair it started because we were all forced into the same forum as all bets were off due to the crash of the site.I have no intention of going through it all again ...
MW
You know you want to.......................![]()
The speed of the conveyor has nothing to do with planes ability to take off.
The speed of the wheels is dictated by the speed of the conveyor, the rearward force of the conveyor is disippated by planes wheels which are mounted on bearings
