Who cares?
Thats a lefty approach, think on...People with children? Think on...
I think it has been found in tiny amounts, tiny tiny amounts, its some byproduct of methane, nothing whatever to do with our crude oil which originates from marine life, or our coal that oiginates from land based plant lifeYeah, it's *******s.
Or to be more accurate, abiotic oil can occur in theory but we've never found any extractable oil that seems to have occurred that way.
Investors business daily is not a peer reviewed journal.
Azerbaijan is not on Titan. Also Methane is not the same as Brent Crude oil.Titan’s surface organics surpass oil reserves on Earth
Nobody said gas or coal - you are making stuff up.No body remotely serious thinks our oil gas and coal has anything to do with the Abiogenic nonsense, its all Bio
If you're going to quote quack websites at least skim them first. That's from your link.Nature magazine calls the product of this process an "unexpected bounty " of "natural gas and the building blocks of oil products."
No its not melting its literally bubbling out of the ground you said.Melt![]()
If I recall correctly, Azerbaijan is as rich as it is because oil literally did bubble out of the ground, making its presence obvious and its extraction costs low.
Yep as you said its literally bubbling out of the ground and its doing so in many areas around the earth where its production allows it to work its way to the surface through rock formations. Its oosing out on it's own accord because the earth is making it itself.If I recall correctly, Azerbaijan is as rich as it is because oil literally did bubble out of the ground, making its presence obvious and its extraction costs low.
Stick to posting what you know about.
You'll have a lot of time on your hands if you do![]()
'Higher' depths?Oil is found at much higher depths than fossils have ever been found which are far deeper.
News flash: Aveatry believes that hot springs are actually creating water in real time.No its not melting its literally bubbling out of the ground you said.
