Climate Change
Everyone should simply calm down, climate change doesn't affect us and neither will running out of oil, all of that is years away and no point worrying over it. Its like worrying over that one day the earth will burn up from the sun and be destroyed. Who cares?
Yeah, it's *******s.
Or to be more accurate, abiotic oil can occur in theory but we've never found any extractable oil that seems to have occurred that way.
Investors business daily is not a peer reviewed journal.
I think it has been found in tiny amounts, tiny tiny amounts, its some byproduct of methane, nothing whatever to do with our crude oil which originates from marine life, or our coal that oiginates from land based plant life
No body remotely serious thinks our oil gas and coal has anything to do with the Abiogenic nonsense, its all Bio
Nobody said gas or coal - you are making stuff up.
Nature magazine calls the product of this process an "unexpected bounty " of "natural gas and the building blocks of oil products."
If you're going to quote quack websites at least skim them first. That's from your link.
Lazy trolling, do better.
If I recall correctly, Azerbaijan is as rich as it is because oil literally did bubble out of the ground, making its presence obvious and its extraction costs low.
Yep as you said its literally bubbling out of the ground and its doing so in many areas around the earth where its production allows it to work its way to the surface through rock formations. Its oosing out on it's own accord because the earth is making it itself.
In other areas the production of oil within the earth builds up trapped within rock formations and builds up so when we stick a pipe in to draw it out it first spouts out under pressure.
You only have to look at the La Brea tar pits to see the seepage has been happening for tens of thousands of years - where do you think its coming from if the earth itself is not producing it. Oil being a fossil fuel is a lie - need more proof - no fossils have ever been found in oil - need more evidence-- Oil is found at much higher depths than fossils have ever been found which are far deeper.
No its not melting its literally bubbling out of the ground you said.
News flash: Aveatry believes that hot springs are actually creating water in real time.
Volcanoes must be some really energetic chemistry. Which I suppose is true.
