anyone know if you can get 15 amp FUSED round pin plugs?
at £4.10 each rather an expensive way to fuse.The BS 546 and BS 196 I have not seen with fuses but in BS7671:2008 it says "BS 546 (fuses, if any, to BS 646)" so I would think you can get fuses for this type.
As someone else has linked MK make them (643 WHI) however the maximum fuse is 5A and I can't seem to find anywhere that actually sells them.anyone know if you can get 15 amp FUSED round pin plugs?
I hadn't noticed that.MK make them (643 WHI) however the maximum fuse is 5A.
I disagree, if you have a small peice of equipment that you aren't happy being protected by whatever fuse/breaker backs up a typical theatre socket (I'd guess either a 16A or a 10A breaker depending on the dimmer rating) then this lets you protect it with an appropriately rated fuse.Bit of a pointless product, really.![]()
