A slightly different take on the problem, that may suit some?...but I'm after a screwless socket that also has USB ports
Why?I suppose you could use a 5 way wago and take two cables to the socket...
That, in itself, would not alter the fact that, strictly speaking, the socket was on a 'spur' from the ring - it would merely have (unnecessarily) doubled the CSA of the spur.I suppose you could use a 5 way wago and take two cables to the socket...
I was researching this late (this is my a disclaimer - I was pretty tired so could have missed something,I'm sure it's just a typo but it's 2 cores into the Wago (one from each side of the ring) and 1 to the socket. And there are 3 no. wagos; one for live, one for neutral and one for earth
Are they saying there's something wrong with it/"technically" it's a problem?
Thank you!! I really appreciate your helpI was thinking they might be OK because they wouldn't usually pull the skin off a rice pudding
These:
Wago 32A 3-Way Lever Connector 50 Pack - Screwfix
Order online at Screwfix.com. Transparent, reusable connectors for solid, stranded and flexible cables. FREE next day delivery available, free collection in 1 minute.www.screwfix.com
If you cut some short (few cm) length of 2.5mm and attach it to the screw terminal on the socket and to one of the slots on the Wago, then you've effectively made the socket into something like an MK Rapid, and you might be able to find a way of doing this comfortably, electric screwdriver, whatever, while watching TV etc.. Then on the job site it's just push push push (you don't have to lift the levers on a wago to fit solid core cable, you can just push fit) - it's cost you 90p to convert the socket but..
One small note, there are non-lever wagos but they aren't rated to 32A
Yeap, there are still the faceplate screws but for the most part an electric screwdriver should be good for those (and pozi ones exist too!)
Sorry, yes - 2am typo. I'm going to go back and check as it was late so I might have missed somethingI'm sure it's just a typo but it's 2 cores into the Wago (one from each side of the ring) and 1 to the socket. And there are 3 no. wagos; one for live, one for neutral and one for earth
I'm embarrassed about that typo!That's an interesting one because, although I've never really thought of it before, I suppose it's technically true (as robinbanks has said, I presume you mean the two ring conductors plus one going to the socket going into a '3-way' Wago)- although I imagine that most people really think of the Wago as being an 'extension of the socket's terminal'.
However, as robinbanks has also said, it doesn't matter, since there is absolutely nothing wrong with a (one) socket being supplied via an 'unfused spur' from a ring.
Kind Regards, John
For £5, I'm happy to try it!! Thank you!!Might a t handle ratchet screwdriver help? Like this for instance
Multifunctional Manual T-type ratchet screwdriver Quick Bolt Driver Batch 1/4" | eBay
Find many great new & used options and get the best deals for Multifunctional Manual T-type ratchet screwdriver Quick Bolt Driver Batch 1/4" at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
It occurs to me that some people might argue with the way I have dealt with the CPC ('earth') in my diagram. If one really wanted to have that as a 'true ring', one would treat it the same as the L & N, and therefore use 6 x 2-way Wagos. However, as I said, I see absolutely no point in that approach in the first place!There would be absolutely no point, but if one really wanted to one could use Wagos to 'extend the ring' to include the socket (so it was no longer 'on 'a spur'), but that would require 5 Wagos (4 x 2-way and 1 x 3-way) ...
That wouldn't make it a ring though; it would make it an unfused spur that uses 5 mm2 cable. It also still has a spare port in the WagoI suppose you could use a 5 way wago and take two cables to the socket...
Is it really a spur if it doesn't leave the confines of the socket box I wonder?That's an interesting one because, although I've never really thought of it before, I suppose it's technically true
Well, in terms of 'conductor paths' it obviously is still 'a spur' - but, as you go on to say ...Is it really a spur if it doesn't leave the confines of the socket box I wonder?
... which, as you imply, makes the whole discussion pretty ridiculousIf we're splitting those hairs, surely the short length of connector strip from the live screw terminal of the socket, to the live plug contactor, and down the live pin of the plug, whereupon it meets a fuse.. That bit is also an unfused spur....
