You could make a test box to prove the connections were correct.
Using Ticklie's suggestion of using appliance leads with moulded on IEC connectors one box could test all the plugs in turn.
Lamps lighting say they got it right makes it more exciting. They can also be left alone to wire the plugs up and then plug them in to test they had put the right wire to the right pin before bringing them to you for a visual inspection.
