Changing backup/stby battery . TS690
In other words Saxondale has backed down (as usual)
no in other words Joe isnt thinking what he is posting (as usual) but saxondale is not prepared to compromise the security of his clients by discussing ways of defeating alarm systems
will say this for the last time - topic closed for discussion
That's because Saxondale knows he's talking rubbish. The manuals are freely available. The most likely crook to attempt to bypass an alarm system is one that installs them and already has the manuals - and knows they are of no use.
your a dangerous fool - the worst kind
What are you blathering about - you don't even make sense.
what you saying about your past life there Joe ?
I'm sorry, but I gonna have to laff! HAHAHAHAHAHAH
Thanks for the thread hijack guys.........
Any chance of an answer to my origional problem or shall i leave you to it here and start a new thread?
sorry flyboy777, if you don't have the engineer code to reset the system then best phone around a few local alarm companies and ask if any of there engineers have programming knowledge of (ts690) to call out and re-programme from the start.
there is nothing worse then having an engineer calling out, second guessing the procedure with a half a tatty programming Manuel covered in stains :lol: i should know Ive been that soldier with other panels :oops:
although i have the menvier ts range 90% memorised :D  8)
Twas answered ages ago - if you`ve got everything back together and it says " call engineer " or similar and doesnt reset with your user code then its on engineer reset for tamper
you need either the engineer code, a reboot or if the codes burnt into the panel the original installer or someone who knows the backdoor into that particular system
ignore Joe - its how he gets off
OK I have successfully done a factory restart and now have access to the engineer menus.
The handbook says the restart resets the engineers code without erasing/changing any other settings, however I now have a "reset config" message.
This sounds like all settings have been erased to me gulp...
any ideas please?
any ideas please?
But, you have the 'handbook' ..........
Yes the "handbook"...
Anyway all sorted now just had to do a learn hardware command in eng menu 1.
