I have read that even some energy saving bulbs which are designed to work with dimmers some times dont work properly, due to the wattage, the buld is a 20 watt bulb but the switch states in requires a 40 watt bulb so you will have to use to bulbs to get the required wattage to make them work like they should do.
All I have is 1 light fitting I want to use 1 energy saving bulb with my dimmer which is 40 w to 250 w.
I would rather not use the old style bulb if I can help it, could anyone give me some advice as to what bulb I should get, or what is the best way I should do it.
thanks
thanks
