Better to use deformable adapters, like the MK 56462.25 mmOval conduit will squeeze into the round adapter if you wanted it too
Yes. It's just a little harder to work on one cable with the other already in place.Question : Can I run 2 x T&E in one conduit, so that I don't have to chase as much out the wall?
I use 25mm oval for 2x2.5mm² T&Es. For AV & network stuff I use 32mm which is (I think) the widest oval they do.Will 2 x T&E fit into a 20mm oval AND 20mm round conduit? I would like to know the answer to this.
Everyone has their own approach, and for a professional it will be influenced by the economics of the time needed.How far should the conduit be inserted into the back box and through the grommet? Or is no grommet needed if the conduit is used?
I inherited Dad's tools for this.This is the experts way of wiring behind skirting boards.
I don't have to ease the skirtings out at all - though in this house they tend to fall off if you so much as look at them (60s house, wooden wedges dried out and loose).
That would not appear to be the case.Because you never contribute anything that is of use.
You needed to replace all of that old and desperately dangerous cable.Only a few months ago I posted about a problem where I found metal conduit in the wall with old cable that was deteriorated. You, as well as one or two others tried to make me believe I needed a new ****ing rewire for all the lighting in the place, costing thousands. Sure enough with the help of my spark mate we re-chased a few cables, earthed the boxes, and I could close up and decorate.
Wrong.You are just here to try and keep people ignorant, and keep sparkies in work.
Got any examples?You DELIBERATELY don't even write proper english to make what you write unintelligible from a laypersons perspective.
It would be nice if that were always the case.You need reminding it's a DIY forum and this is a DIY electrics sub forum, people come here to learn
Got any examples?not to have regulations barked at them.
What you will have seen me "do repeatedly" is to advise people who are not sufficiently competent to get an electrician. Electrics are unlike other forms of DIY - if you mess up some joinery, or decorating, or gardening for example, you won't kill yourself or others with doors that don't fit properly, or paint with runs in it, or a dead rose bush.The soonest possible opportunity you tell someone to go and pay a professional person to do it, whatever they may be doing no matter how small, I've seen you do it repeatedly.
I don't think that at all - there are lots of people here who know more than I.I think you think you know it all, and there's nobody on here that can match your knowledge of electrics, you're wrong.
I don't "project" myself in any "way" which should cause resentment.Not only that, the way you project yourself makes me resent having to talk to you at all.
You do not have the right to declare who may or may not post here.So that's my problem with you. I have the courtesy to actually answer your question honestly and clearly, like you never do to me. So now I've been clear can you stop posting in my thread, because I didn't come here for a fight, I want to get on.
What about Regulation 12?I just need to know if there is anything I've done here which will void building regulations
Well - in the spirit of you coming here to learn, I shall inform you that it does not work like that. An electrician may not "sign off" work done by somebody else.because I will be having it signed off once completed and the connections will be made to the C/U by a sparky.
You can always put 2x16mm ovals in - these will fit neatly into 20mm grommets.
The most common technique I've seen is to run the white conduit to within about 1/2" of the box, then dog-leg the cable to fit through the grommet in the box. It's the quick and simple way, but makes future work harder.
If the conduit is small enough, you fit the end into a grommet in the box - this won't work with 25mm oval though as most boxes only have 20mm knockouts.
When I learned from Dad, it was all hacksaw and file. Now I have a nibbler (like this) that makes quick work of enlarging a hole so the oval fits in without distorting it.
And then I carefully de-burr and radius the inside of the conduit end and leave it just flush with the inside edge of the back box.
- A long thin chisel made from what looks like a bit of 1/4" (ish) round bar with a slight bend so it sticks out from the wall far enough to be able to hit one end while the other end goes down the back of the skirting.
- A drill with a sleeve and home-made universal joint that will go down the back of the skirting and drill through the board if it's butted close to the wall.
If your "sparky mate" did a quick bodge which did not involve such a replacement then he was neither a sparky nor a mate.
Wrong.
Got any examples?
But it isn't. Some people come here expecting others to do things which they need to be doing themselves. And some refuse to learn when they find out that they don't want what they are being told to be true.
Got any examples?
DIY electrical work must be done to the same standards as a professional would do.
What you will also have seen me "do repeatedly" is to tell people that getting an electrician is one choice, and that the other is to actually learn the things they need to know to be able to do the work themselves, often accompanied by links to learning materials. As in "people come here to learn".
Did you apply for Building Regulations approval before starting this work?
Either you notify the work in advance, and gain agreement from the council about how you will comply with Part P, or you use a registered electrician or you use the services of a registered 3rd-party certifier, but they too must be found in advance.
It's certainly possible, but I must say that I have had serious struggles at times. It's not so bad if one feeds both into the conduit together, but if one puts one in and then tries to put in a second, my experience is that any lack of perfect straightness in either of the cables can make it very difficult. I wonder what is the experience of others?If it's any reassurance, you will get two 2.5mm2 t+e cables through a 20mm oval conduit or a 20mm round conduit.
That's certainly true if the cable(s) is/are in (adequate) conduit, but I'm not sure that capping would make life much easier, would it?Always use conduit or capping, because putting cables directly in plaster only causes problems in the future if any damaged cables need repairing or replacing, or alterations are made.
Or make more boxes with oval knockouts.Im surprised they do not make something like these with a thread and bush
