- Joined
- 21 Jan 2017
- Messages
- 94
- Reaction score
- 1
- Country
Hi Guys,
Wondered if you could all help me please regarding my kitchen sinks external weld waste pipe.
Six years ago had an extension done on the home, though in the last 2 years my kitchens external drain waste pipe has been leaking a little from the outside on the wall. Could anyone advise me on the pictures based below, please?
From what I understand of it, the waste drain pipe which connects to the trap comes outside which is then connected to another drain pipe via a compression slip nut in between both pipes tight against the wall. To my understanding, this does not seem to be doing the job as this is where the leak is.
Possible Solution below
I have a suggestion in mind to fix this, which would be to buy a 45 degree or 90-degree bend offset pipe, solvent weld this between the drain pipe which connects to the trap and comes out the wall, then connect (solvent weld) the other side to a new 40mm drain pipe. Using 40mm wall clips to keep the pipe in place. Of course, if the internal/external drain pipe which connects the trap just falls short off from coming outside the exterior wall a little, I could just attach straight coupling connector to it to extend it a little, right? . Regarding the brickwork ill chisel of some of the grey mortar first and at the end of the job, patch this up with new mortar (Red dye) to match the bricks a little.
_____
Please do let me know your thoughts on my solution above please guys, or if you have any suggestions or better solutions/tips then please do let me know. Sadly, I am short of funds atm to get this fixed so I want to try and do this myself.
Thanks to all who reply in advance pictures are below.
_____
