"Page 1" of what?
This thread, where you'll find I already linked to that.
"Page 1" of what?
That's the 10" SOHO stuff I was talking about. The downside is that it's not as widely an adopted standard as 19", and as a result it seems to be more expensive with less parts available. Ideal if you haven't got much space, though.
Sorely lacking in quality hardware. Like gigabit switches.
Personally, I can't stand non-rackmount kit in rack cabinets, but sometimes it's unavoidable. Just like wall wart transformers that you can't direct plug into an IEC320 PDU![]()
I have a dirty hack for that. Take an AT PSU, cut the switch cable back inside the enclosure, fit a toggle switch. Butcher external wiring as needed. One well regulated, efficient, central power supply for +5V and +12V. Could very easily modify a smaller form factor PSU to fit into a rack mount equipment case.
Mine is sorely in need of cleaning up and rewiring, but it works a treat.
I chucked out my last remaining AT PSU nearly a year ago now
My past solution has been to replace wall warts with inline PSUs with an IEC inlet, but when you've got lots of kit running on different voltages, it becomes more unwieldy than having a load of wall warts plugged into an extension strip.
Well you can use an ATX PSU, but there's more work involved. The switch is easier (no need for a 240VAC rated switch), but you often need to provide some fixed load or you'll get crap voltage regulation.
Combine with a panel of (marked and keyed, obviously) 5V and 12V outputs (3.3V too if you're using an ATX supply), and you've got a neat and effective solution, cheaply too (even a good quality ATX PSU, new, would only set you back 30 or 40 quid for this use). You can even individually switch the outputs quite easily.
Blah, domestic routers. Terrible, cripped, subpar crap, and the business stuff just has a different case! Mine has an ATX PSU and lots of RAM.
Yep, definitely digressing.
You'd be surprised, that router might well take 48V. Open it up and see.
I kept it simple by screwing a patchboard to a panel in a utility room cupboard. The panel is hinged at the bottom.
Looks interesting. Any chance of a photo with the panel open? Thanks.
I like the idea, although I'm hoping that I will be able to ditch a lot of PSUs when I convert the CCTV to PoE IP cameras, and replace the router with one that supports 802.3af PoE rather than the nasty proprietary 12v that my current router supports. Mind you, it would be a shame, as it's a very good router otherwise, and even has gig WAN ports.
I think we're digressing now...![]()
