Regarding those big industrial round plugs, are 16 A plugs/outlets the same size as 32 A plugs/outlets (i.e. would it be possible to plug a 32 A machine into a 16 A socket or are they incompatible)?
That's the whole point.Different size, ISTR the 32A ones are larger than the 16A ones.
I suppose there is little/no need in UK/Europe - which I imagine is why all the 4-pin and 5-pin ones I've seen are red.Off-topic.....Currently working on a project with 3 phase + N + E blue c-form connectors.....didn't even know they existed prior to starting the project.
Do you mean 200V phase-phase - i.e. about 115V phase-neutral?The project is in Japan, where mains supply is 200V three phase, either 50 or 60Hz depending on location.
Kind Regards, John
Mennekes make (and sell in the UK) ALL the plugs and sockets you could ever want. There's a 5-pin blue, 5-pin yellow etc, even do a few 3 pin red.I suppose there is little/no need in UK/Europe - which I imagine is why all the 4-pin and 5-pin ones I've seen are red.
Kind Regards, John
At least from wikipedia there seems to be a bit of a gap in the standard for the 5 pin plugs. The yellow is for "57–75/100–130 V" and the blue is for "120–144/208–250 V AC", so there doesn't seem to be any correct plug for 100/173 .Having said that, they quite clearly categorise the blue 5 pin as being for 230v
