- Joined
- 17 Oct 2005
- Messages
- 225
- Reaction score
- 3
- Country
trying to get rid of an air lock in our boiler after emptying central heating system and looked in the airing cupboard at this setup . the alarming thing I found was going up into loft at the F&E tank expecting to see the cold feed being a 22mm ... but its only (equivalent) of 15mm - I say equivalent because our house we are in (Ireland) has not got the normal 15mm and 22mm copper piping for the plumbing it has this (expensive) German made metal pipe you can bend easily by hand (more easier than copper) and is covered with some white plastic outer material. The bores look even smaller than 15mm copper does , but its not microbore pipe.
but I think its a weird setup , 15mm (or equivalent) for the cold feed from the header tank in the loft but the expansion pipe 22mm (or equivalent).
here is a rough drawing:
