Softus said:What's that all abaaaahht?
Yes but its a multi-compartment safe. The sheet metal door safe is inside the top of the main safe. The main safe has a cast iron door. This was open. The inner safe was also open (this is where the air tube deposits cash from the tills and is time delayed). I had been counting in the main safe, and stood up . . . .RF Lighting said:Is your safe not on the floor then?
Crafty said:Yes but its a multi-compartment safe. The sheet metal door safe is inside the top of the main safe. The main safe has a cast iron door. This was open. The inner safe was also open (this is where the air tube deposits cash from the tills and is time delayed). I had been counting in the main safe, and stood up . . . .RF Lighting said:Is your safe not on the floor then?![]()
nonono thats my date of birth!!!Spark123 said:Thats the easy bit, 1289!!
Which co-op did you say it is again?
Crafty said:nonono thats my date of birth!!!Spark123 said:Thats the easy bit, 1289!!
Which co-op did you say it is again?![]()
LOL Just ask JohnD!
Nah that was a door access code anyway, not such a sensitive info. And the safe codes are 6 digits. I COULD give you the inner safe code, but that wouldnt be just use without the outer safe code![]()
