i think giving it all up is a bit extreme really.it doesnt cost that much and you can charge it all on
No - but the frequency of some of them can be increased by putting restrictions on DIY electrical work...
you don't expect to have to check neutrals for mains voltages after switching off a circuit at a DP Switch (I do now).
How do you decide what is "complicated"? Given a few minutes I, and you, could find evidence here of people for whom a light switch is too complicated...i started that about banning sales of electrical items.
what i meant was the more complicated stuff should be kept out of reach.
Apart from the supply isolation issue, then with a reasonable amount of common sense, including enough common sense to realise that they should find out a little bit about it, what can go wrong, or get worse, if a DIYer carefully replaces an old CU with a new one, and possibly end up with MCBs where he previously had rewireables, or an RCD where he previously had none?to my mind its foolhardy and dangerous to let a diyer loose on a new CU for example.you wont know the regs,be able to do the testing and so much could go wrong,the consequences of which dont bear thinking about.
Indeed there is, but there is no circuit design involved in removing conductor ends from one set of protective devices and inserting them in others, and circuit requirements do not become more onerous when switching from fuses to MCBs.yet you can get one from the sheds for sixty notes and walk out,totally oblivious to what your supposed to do with it.
there is more to safe circuit design than connecting pieces of cable together
It's not an idea with any official support, is it?I think the recent idea of restricting access to parts and information will likely not achieve its goal of reducing DIY casualties, and may indeed have the opposite effect.
I don't think so.sometimes perhaps grandfather rights should be allowed...??
So if part P is necessary why don't you need a qualification to use a tumble dryer!
