His son might be a fireman...........
The supply from the house to the outhouse had become disconnected from the earthing system because of a fault, the inquest was told.
Another fault meant that when lights were turned on in the garage, the wiring and sockets which led to the radio became live.
http://news.bbc.co.uk/1/hi/health/4316203.stmDespite widespread fears about poisoning and electrocution, annual deaths from these were in single figures.
You helped him to comply with the law, as the law requires him to make reasonable provision for safety.now i havent condoned someone breaking the law,but i did help him as there was an obvious dilemma there.
There's no law against it.you can buy a boiler and fit it, they dont tell you you cant connect the gas to it though. (learnt that in the plumbing forum)
No.It seems a very clumsy and expensive way of putting in some quality control, and was there a big problem needing sorting in the first place?
That might be because the Fire Service don't like to put "dunno" on the forms and if they can't find an obvious other cause they often put "electrical".^yeah but its not just electrocution, i saw some statistics for house fires recently which suggested that the majority of fires were bad electrics.
On the other hand I would much rather they replaced a damaged or inadequate CU rather than bodge something together using the existing CU and whatever bits they could get thier hands on.i started that about banning sales of electrical items.
what i meant was the more complicated stuff should be kept out of reach.
to my mind its foolhardy and dangerous to let a diyer loose on a new CU for example.you wont know the regs,be able to do the testing and so much could go wrong,the consequences of which dont bear thinking about.
There is indeed but provided the user uses type B MCBs (and you have to go out of your way to get other types, the diy sheds don't stock them in my experiance) of the same rating as before then the overcurrent protection probablly won't be worse than it was before. I suppose they could put circuits on non-rcd that were on rcd before and make them less safe in that way but quite frankly we lived without RCDs for a very long time and afaict electrical death rates were already pretty damn low.there is more to safe circuit design than connecting pieces of cable together
