He states cooker area is in the safe zone as there are no diagonals so also to the regs.
That red route is NOT in a safe zone. That it contains no diagonals is irrrelevant - what accessory is it horizontally or vertically in line with?
"To the best of my knowledge and belief" qualifies his assertion that his work complied with the Wiring Regulations.What is the 'falsehood'? He will preumably have signed a declaration which includes "...to the best of my knowledge and belief..." and the OP has said:His EIC contains a falsehood, and he has signed it.
He hasn't falsified documents....in his mind its ok.
It does, indeed, and if it transpired that his knowledge and/or belief were actually incorrect, that would not render 'signing for that' as a 'falsehood' or a 'fraud'."To the best of my knowledge and belief" qualifies his assertion that his work complied with the Wiring Regulations.
We would need a lawyer for this one. For a start, "...having exercised reasonable skill and care..." actually appears before "...hereby CERTIFY". More to the point, you are effectively trying to use this to negate the "...to the best of my knowledge and belief.." (which comes after "...hereby CERTIFY.."), since you are presumably primarily suggesting that there was a lack of 'reasonable skill and care' consequent upon knowledge and/or belief about the regs being incorrect."He also asserted that he had exercised reasonable skill and care. That assertion was not qualified. And it was not true.
I will put everything down in writing on an email then he can decide what he wants to do. Should the whole kitchen be on a ring not a mix of radial and ring
I'm told the circuit comprises of 2 A3 radials and a ring.
So where are the 20A breakers for the A3 radials?32 on the kitchen sockets
32 cooker
32 (upstairs and downstairs on same socket breaker)
Lights are on separate upstairs / downstairs breakers
MCB is 63
If it were true, it could well be.Is this A3 radial business acceptable?
