commercial links removed
I am purchasing a lower-ground floor flat which currently has all of the plug sockets and wiring surface mounted in trunking. I'm undertaking a renovation project on the house soon so now is the time to get them hidden!
I am looking at installing a wet UFH system between a concrete slab and my engineered hardwood flooring. It consists of a 15mm insulated panel with an MDF base.
Would it be possible to route the plug socket cables through the under floor heating panels beneath the flooring so they are hidden, and then I would just bring the plug sockets up onto the wall where they are desired?
I'm aware that it would mean there is both water and electrics running under the floorboards so a leak could be very bad news.
- Are there any building regs which forbid this?
- If not, is there anything which I could house the electrical circuit in which would protect it if the under floor heating were to leak?
The alternative is to chase into the walls, however this is more time consuming, intrusive and therefore expensive, but if it's the only way then so be it!
