So next job is to bed a 4x2 sole plate on to the block work. Going to bed it on with a thin layer of cement and DPC to make sure it’s level. Then we’ll be flying.
I would screw the base plate down to the blocks tooSo next job is to bed a 4x2 sole plate on to the block work. Going to bed it on with a thin layer of cement and DPC to make sure it’s level. Then we’ll be flying.
I think I'm safe on that front as my garden is just over an acre in a very rural wooded area so well hidden. But thanks.
Then again if you keep records from your build i.e. rental paperwork for the digger, paperwork from materials suppliers etc., this form an evidence base to prove the date you built it. After four years, even if the workshop did need planning permission, but the local planning dept. didn't pick this up, then the workshop would be Lawful Development. This wouldn't mean that the workshop got automatic planning permission after four years. It means that after four years from the time it was built that the workshop would be immune from planning dept. prosecution. The onus would be on yourself to prove when it was built (hence saving all the paperwork, photos etc.).
