H
heatgas
How is this anything to do with gas safety? , give the guy an answer.
will you explain it or not? it would be most helpful if you COULD.
000000000Not enough Zeros!!!
will you explain it or not? .
Why can't you guys be helpful, or just shut up?
These figures were read from a flue gas analyser. They are good.
CO2 and O2 vary inversely with each other, and it is usually the oxygen value which is measured nowadays, although in the past carbon dioxide was measured with wet analysers. That is why both figures are in use.
Carbon monoxide at 1% in air is indeed fatal, but the analyser is measuring the concentration in the flue gas, not the air in the room, and the figure quoted is OK.
OP, if you haven't already jumped off a cliff!!
..the OP did ask!!
My Worcester Bosch Greenstar 35 Combi boiler has just been serviced under an annual Homecare agreement
