- Joined
- 13 Dec 2007
- Messages
- 4,009
- Reaction score
- 662
- Country
He could have an outside privvy...
There is probably a paragraph in the lease permitting it. If there isn't, the lease is defective. This should have been picked up by the Conveyancer.How are you going to get around the fact that a boiler flue (condensing OR NOT) is not allowed to terminate into/onto land which you do not own?
I checked. This is an oldish attractive block (it is no ex council job, although some of those are done up superbly) and was made-over about 15 to 20 years ago. The only penetration of the walls of the flats were to get gas mains pipe, electric main cable, telephone and a communal aerial in. Also the flues of the combi's, which all discharge onto the common landings at the rear and one side of the block. Nothing penetrates the façade of the block. No overflows from the toilets penetrated the walls as all are on tundishes. Newer toilets overflow into the bowls eliminating tundishes. The combis's high pressure overflow pipe goes into a 3/4 inch brass tundish and away to the old cast-iron soil stack.There is probably a paragraph in the lease permitting it. If there isn't, the lease is defective. This should have been picked up by the Conveyancer.How are you going to get around the fact that a boiler flue (condensing OR NOT) is not allowed to terminate into/onto land which you do not own?
.........and denso13's posts about exemptions
The apologies are the other way. Many of the "professionals" were proven wrong by mainly D Hailsham not me. For the benefit of others, mention the non-condensing boilers available. I am going for the Vokera SE irrespective because of its simplicity. It is also well priced, but that is not the prime reason for choosing.If you apologise for trying to belittle law abiding engineers, I'll mention a couple of boilers.
I have read it as D Hailsham did, who even posted parts of the regs. I see an exemption. Will you explain your reasoning from your reading of the document?I posted a link to the paperwork but, IMHO, it doesn't give you an exemption in this case..........and denso13's posts about exemptions
He doesn't have to have fitted a boiler, no more than an architect needs to know how to mix concrete. D Hailsham can interpret regulations, as can I, and that is what matters on this thread. I checked out his conclusion and he was right of which many will thank him for who read this thread.D hailsham has never fitted a boiler in his life.
Can you show me that law please? You are 100% wrong. No flat owner has the right to fit equipment in someone else's property unless that person or organisation gives permission. That is very simple and fundamental in law. In my case the lease is very specific and later letters have clarified the situation. This will be the case for 99% of blocks of flats. Even in a house you cannot have a plume wafting across a neighbour's open window, so a non-condensing boiler/combi can go in there.I checked out his conclusion and he was right
He wasn't.
As I said before the owner's preferences don't come in to it, it is the law.
