It's no secret on here that I work for intergas and if you reread the thread you will find that I've insulted no one.
Not even a total coont like you
You and Robinson are enough to put people off Intergas. Well you put me off. A relative up country emailed and wanted a recommend on a replacement boiler in Spring, with me directing him to a Ferroli 38C. He emailed a few days back. Their noisy old 20-25 yrs is boiler is clapped out and needs renewing. It heats the rads directly with an old copper cylinder. They have excellent mains pressure & flow. I suggested a Ferroli 38C which gives an impressive 16.4 l/min and get rid of the cylinder, releasing needed storage space. I suggested keeping the loft cold water tank, because it is already there and takes up no space, and have it feed the toilets, bath (they use baths a lot), bathroom basin and the two wet appliance in the kitchen. Spread the load over the cold mains and cold tank. Remove the power shower pump and have only the shower and kitchen on the hot & cold mains. Also to get a larger shower head to take advantage of the Ferroli's hot water delivery. If Intergas had a model with similar specs to the 38C I might have said look at that. If the specs are similar go for the better deal, and that will be the Ferroli.
BTW, all employees are salesmen in one way or other but you cannot figure that out. Don't get above yourself, you are not an engineer you are an on-the-tools boiler serviceman. You and Mr Robinson have no background in engineering. Real engineers are thinkers and do not have attitude. The likes of Bernard are engineers.
The Modena is better than the current Intergas range, it is a quality product in build and design. I doubt you have seen one in action - until the Intergas HRX comes out (and the jury is out on that). The Ferroli has a `one piece` with no joins stainless tube-in-tube heat exchanger, not the heavy over engineered, full of joints lump seen on the Intergas. Not one Intergas heat exchanger has ever failed? Sure mate! Pull the other one Intergas. The Intergas 40kW model only delivers 13 litres per minute of hot water.
That is a disgrace! I have had experience of both. To say the Intergas is better is total boIIocks. The Ferroli delivers 16.4 litres per minutes, about 26% more than the larger Intergas. It also modulates down lower.
Intergas backup & service is not better than Ferroli. That is spamming a product by you and your insulting Intergas henchmen. Long waits on telephones is common. Long waits for servicemen are common. They do not cover all the country effectively.
Travelling through the thread it's obviously that I am a level above the on-the-tools-men for sure. So is Bernard. One offensive man was well spanked by Bernard and myself.
And our education shows in our civilised attitude and broad minds. Tradesmen are `trained` not educated. The aggression from them here is a sign of intellectual inferiority.
