What's going on here?
What if, hypothetically, the circuit served six fans, six shaver sockets and one light, or some such combination of loads. Would it still be a 'lighting circuit'?
Hypothetically yes.
You definitely need to find another career if you think a cooker circuit can be wired in 1.0 mm cable.
Clearly it was for a gas cooker, so the power requirements were only for the ignition device and a light inside the oven, making it a lighting circuit after all.
I connected a fixed light to it - and there was one in the hood.
Is a piece of paper the defining factor? .
A lighting circuit is a circuit wired in 1.0mm² cable or larger (and powering at least one fixed light?)
As EFLI has implied if, like you and winston, one says that just one fixed light supplied by a circuit renders it a 'lighting' circuit, then all sorts of circuits (like EFLI's cooker example, and many circuits primarily supplying sockets) would qualify as 'lighting circuits', and that would obviously be ridiculous/daft.
If we must have a distinction between 'lighting' and 'power' circuits (and I personally don't see why we need one), the I would have thought that the only sensible definition of a 'lighting' circuit would be along the lines that it 'primarily'/'largely'/whatever supplied lighting loads.
... and what happens about the 'heavy' stuff - is the circuit supplying, say, the floodlighting of Wembley Stadium not a 'lighting circuit' (since I imagine that it has an OPD >16A) ??
Lighting circuits were originally charged at a cheaper rate for lights only. The name has stuck. Some people cheated of course and used bayonet adapters with their irons, vacuum cleaners, toasters etc.
