Typo. It's not an exposed-c-p.The back box is not an extraneous conductive part
Well, to be fair, it's not either sort of "e-c-p" (unless the plaster/wall is very wet all the way down to the ground!). However, as you imply, it's probably not what TTC intended to type!Typo. It's not an exposed-c-p.![]()
Neutral is a live conductor.Also they can glow when touching an Earth or Neutral if the person using it is close to a Live cable ( switch drop for example ) and NOT glow when touching a Live conductor.
Then so is the CPC a Live conductor, or do the electrons change uniforms when they cross the border between Neutral tails and CPC in the cutout ?Neutral is a live conductor.
No it isn't. It is a protective conductor as it is not intended to carry current during normal operation.Then so is the CPC a Live conductor, or do the electrons change uniforms when they cross the border between Neutral tails and CPC in the cutout ?
You aren't very good at this, are you....
Some do, and some dont't. ... and, in any event, plastic ones such as you kindly linked to obviously do not need earthing, via faceplate screws or anything else!... the purpose of the link was to show waffleman that plastic boxes have earth terminals, it's the little brass thing in the corner.
543.7No it isn't. It is a protective conductor as it is not intended to carry current during normal operation.
Let's see. John said "Be aware that the same is not usually true of plastic switches (like light switches), since they have no earth connection, so cannot earth a back box via faceplate screws".Are you getting confused? can't keep up? the purpose of the link was to show waffleman that plastic boxes have earth terminals, it's the little brass thing in the corner.
That might be a factor contributing to your desperate incompetence.my eyes start to close after the first few meallymouthed words.
Do you really think anybody reads your waffle, my eyes start to close after the first few meallymouthed words.
Quite so. He's not the only one, but it does rather look as if he may have a very troubled life, and his posts suggest that his participation in this forum could well be making that worse for him.Don't get why the attitude watson? Surely life is easier when we all collaborate. Seems you are very bitter about life and want others to fail. Are you like Risteard and think this forum is a closed book only to be opened when it suits you? What's the point of you being here? I come here to learn. Attention seeking maybe ?
