Hello,
I have an internal timber door that has dropped by a few mm, presumably due to the hinges getting worn over the years.
Here are a couple of photos; the first one shows the hinge in its usual, dropped position...
...and this one shows it with me lifting the door into the position where it should be:
So, I could buy a pair of 100mm hinges (the existing hinges are 3 7/8", so about 98mm) and try to find something that looks old and has matching screwholes, but I was wondering if anyone knows of a way to fix an old hinge? Googling anything about fixing door hinges just brings up pages of results about fixing doors whose hinges have pulled away from the frame, etc. but nothing about fixing the actual hinge. What I really need is some kind of C-shaped washer; is it normal to push something like this into the hinge, and have it actually work and not drop out? The hinges don't seem to come apart - there's no visible pin which can be tapped out - I'm not sure what magical method they used to make these things.
So - in a nutshell - any ideas on how to fix a hinge?
Thanks in advance for any suggestions!
Paul
Paul
