The 13amp fues in the kettle socket should blow long before any damage is done to the cable?.
Which cable?The 13amp fues in the kettle socket should blow long before any damage is done to the cable?.
What is screwed into the wall under the cabinet where the "host" socket is?
Which cable?
And what relevance has any of that to a socket which has stopped working?
Apologies, missed that.I asked about fcu Monday 8.59 securespark ,the answer was no.
Cheers. But no need to apologise ,this was wired up ten years ago ,not beyond the bounds of possibility that Trevor is mistaken.regards TerryApologies, missed that.
18 hours after I'd kindly pointed out that the kettle could not have had anything to do with the problem.From reading this thread the OP was thinking a defective kettle boiling for too long has damaged the spur cable, I was kindly pointing out the fuse in the kettle PLUG should blow long before the Kettle lead or spur wiring are in any danger of damage due to the defective kettle.
Have you?Have you got any constructive input or are you just trolling?.
