- Joined
- 28 Apr 2004
- Messages
- 8,411
- Reaction score
- 1,008
- Country
Duraplug, MK
Why change the plug when it was ok in the other socket?Replace the plug as well.
My comment was because "red hot" seemed to be somewhat more than a bit of hyperbole.
If they were "red hot" they would have been glowing (incandescent) and touching them would have given you a painful burn.
No I've not tried that we've only noticed it when the dryers on. I'm sure I've charged my drills etc Bluetooth Speaker in there fine not that they would draw as much as the dryer.Have you tried swapping the good socket with the 'bad' socket and seeing if the heat problems goes with it?
If it does then it would confirm the socket is at fault, especially if it stays cool in the original 'good' socket which is now in the 'bad' socket position.
They were red hot to touch
Did you change the plug as well as the socket?Right I've changed the plug socket and it's been fine, apart from today Mrs put the dryer on and because we were due to go out she pressed the high heat button went to check on the dryer 10 mins later and the live & neutral pins were hot to touch, tried the other socket and it was the same,so I turned the high heat button off and left it another 10-15 mins went back and the pins had cooled down....
No i'll do that tomorrow just wanted to try with just the socket changed firstDid you change the plug as well as the socket?
That was probably a little foolish, since you might now have damaged the new socket. As was said on Saturday ...No i'll do that tomorrow just wanted to try with just the socket changed first
