Hi all, this is my first post on this forum, but I suspect not the last one...
I'm replacing one of my ceiling mains-powered smoke detectors with a battery-powered one that is also much smaller. The diameter of the old one was 12cm and the diameter of the new one is 6cm.
After taking off the old one, there is obviously a 12cm spot with about 6cm hole that needs covering. I am trying to think of a simple way to cover the 12cm spot and attach the new smoke detector to that cover (trying to avoid plastering, etc.). In my head I see some sort of plastic cover plate either glued or drilled (but in a way that the screws are not seen) to the ceiling and the smoke detector glued / screwed to that plate (the detector weights 70 grams).
What would people recommend I do? Is there something off the shelf I could buy to achieve what I am trying to achieve...?
See the attached photo.
TIA!
TIA!
