Accidental nick to socket cable
A nick to an electric cable should be taken seriously. People have died, particularly when water comes into contact - as in the two cases below. I'm not suggesting that this could happen in the OP's case, but it's always something to consider. Insulation tape is never the answer, it often comes off after time.
The case of Emma Shaw was the result of bad electrical work by a builder, not a simple nick of some insulation.
So this
is in a wall void?
TBH, if it were me, I don't think I'd even bother with a bit of tape....
Neither of the two is a simple nicked outer sleeve on a cable, the mechanic protection, as is under discussion here, which is more than satisfactorily repairable with a few layer of tape. Those examples given are where a screw has pierced the cable, and made metalwork live. The first case seems to suggest, that an additional fault, not mentioned, was that the boiler seems not to have been earthed. Both were likely preventable deaths, had RCD's or RCBO's been fitted.
That really depends upon the nature and location of the 'nick'.
In the presence of RCD/RCBO protection (probably not present in either of the cases you mention), "water coming into contact" could well be an arguably 'good' think, since it could well cause the protective device to trip before anyone got an electric shock.
