Ok, here goes.
Yes, the shower appears to have two rcd's "protecting" it and no cpd.
The Wylex cover I took off.
The 16mm² tails in the CU are connected to "MAIN" and the thinner tails (the supply from that dist. cabinet) to "LOAD".
I could not find the point at which the supply cable SWA enters the static. All I could see was that which you see in the pictures - I had no idea of where the earths were connected nor what to: I could not figure the earthing arrangement. I was fully expecting TT, but I could not find any rod nor meb's come to that.
The main supply cable goes into that (125A) DP switch, then loops out to feed several rcd's. I could not be sure what fusing device was protecting that main supply, but more importantly, I could not figure out the wiring in the dist cabinet beyond the rcd's.
Surely the feed should come in, go into an RCD, out of the RCD into a CPD and out to the meter, then from the meter to each static?
I can see that each static has an RCD & an MCB, but I could not trace this wiring through. And why two meters?
There is no protection against Direct Contact in this cabinet, either. This cabinet is indeed locked, but each resident has a key so that they can reset their RCD should it trip.
Imagine doing that in the dark when it's sheeting down...
And how does this supply, with that very thin SWA cable, support a 40A shower circuit and the rest of the installation?
But back to why I was there - the sparking fusebox...
A guy had been out to fit a few sockets and had failed (miserably) to tighten up the neutrals at all. The screws were so loose, they were almost falling out of the 'bar.
This had unsurprisingly, caused heat to build up, burning the wiring and tracking back through the main switch. You can't see at all in the pics, but around the screws that hold the CU innards to the wooden frame, there is lots of goo; broken down bakelite (or whatever it is) due to excessive heat build-up.
John & Dart - yes, I kept my hands in my pockets (when they were not, they were glove-clad!) and I ran away as soon as I had written out a form detailing the failures......
This has got to be my all-time favourite electrical b@lls-up yet!!
