But unlikely to fit in a 2A plug and as above too easy to fit a bigger fuse.As below
They are just 2A BS 1362 fuses. I use them extensively, and also 1A ones, but I somehow doubt (haveen't seen) a 2A plug into which they would fit.As below
You would have to ask that of the 'clever clogs' who come up with such ('negative') objections and complications! I merely attempt to pre-empt them!And why is everything a negative on this part of the forum …it can be done this way or is everyone a f*ckwick and wil leave a 13 amp fuse in it ?
The whole point about the negativity (I assume you are including my comments) is standards.And why is everything a negative on this part of the forum …it can be done this way or is everyone af*ckwickF**KWIT and wilL leave a 13 amp fuse in it ?
Fair enough.It’s not a DIG at anyone …sorry if you think that’s what it read ….I just find the whole electrical section a bit like the two old guys from the muppets ….spinning off into other tangents and going around in circles ….
Yes I get that but I also understand your comment assumed it included mine, this doesn't offend me at all in this situation and felt a little explanation was valid.It’s not a DIG at anyone …sorry if you think that’s what it read ….I just find the whole electrical section a bit like the two old guys from the muppets ….spinning off into other tangents and going around in circles ….
Yes I knew they were/are? available and I always believed them to be standard 20x5mm fuses, which as I stated before are available to 35A.2A fused plugs were made by MK. Not sure if they are still available new. The fuse was the same size as in a clock connector and were available up to 5 amp rating.
Also 20 x 5mm glass fuses would fit.
BS646 are ¾" long ~19mm and noticeably shorter and just a little fatter than 5mm.Think those fuses might be to BS646 and also used in 13A -> Shaver adapters
I know of a school theatre installation, where 15A plugs were used to suit the dimmer packs, but they were fused and 5A fuses fitted to allow the use of 0.75mm flex and those fuses were to BS646. I've not seen fused 15A plugs anywhere else
I can't speak for the socket, but, without doing the experiment, as for the pins of the plug, I think they have a CSA of about 10mm² - so I would guess that, in terms of the pins, it would probably take something like 60A or so to raise its temp to 70 °C.Firstly I am not surprised that despite the official 2A rating of the plug, that the design can likely handle way more current than 2 amps. Would be interesting if someone could put this to the test and see how much current a 2 amp plug can handle before it reaches 70c or what ever temperature is deemed as to high.
I think yopu were actually clear enough, even if none of us responded particularly directly to your question! I did, in post #5, write "... It obviously does not feel very right ... ", but I then did go on to say (much in keeping with the above comments) "..... but I wouldn't personally be all that concerned. If you look at the pins of a 2A plug (and the corresponding bits of the socket), then, despite the 'rating', I'm far from convinced that they would be any less able to carry 13A than a BS1363 plug /socket."Secondly, I meant the question from the perspective of the client wanting an adaptor made to convert the 2 amp plug into a normal trailing socket and how one would react to such a request, sorry I did not make that obvious.
That would be 'nicer' (although I'm not sure that such animals exist), but there would still be those 'clever clogs' who would be concerned that someone might change thge 2A fuse for a 13A oneI guess the best thing would be to try and find a single trailing socket that you could fit a 2 amp BS1362 fuse to.
