The 12 kW version can cope with two low flow taps - the makers sell it saying that
so why mention a 9 kw in your post and why not mention low flow taps
you sir are either misleading or an ass get it
The 9 kW electric heater needs a cable. That is no secret. You size the cable to suit. No secret.
Cable sizing is easy to google, cable heatspecs are not. That is why I asked you in my post what the heatspec was, not the cable size.
so why mention a 9 kw in your post and why not mention low flow taps![]()
you sir are either misleading or an ass get it![]()
One quality, combi and cheap B&Q cheapy for backup. Both using the same gas pipe, as they will not on at the same time.
Again..The two combis are cheaper to fit.
Do you understand what 100% CH & DHW backup means?
Or did you use another excuse than diversity to use only half the capacity of the gaspipe of what was needed?
Again, NO its not.
yes perfectly. Do you mean like a 9kw water heater replacing a highflow combi? if not get back to me.
and george
How can you apply the diversity factor to get away with a gaspipe that is only sufficient to feed one boiler? You can not guarantee that the the user won't turn both boilers
