Benjamin
Don't let your arrogance cloud the facts.
Let's just hope you know more about soldering than you do about L&T issues.
The rights and obligations under a Tenancy Agreement are unrelated to those under the GSR regs.
The lawful procedure is as I stated above
Rest assured I know a lot more about gas issues than about l&t issues, my knowledge of the latter is limited to the essentials; contrary to your own knowledge, which is generally very limited.
That is why I have my own business, and you work for the council.
Some of the essentials are:
Tenants MUST allow entrance after reasonable requests for access.
Landlord MUST ensure safety of tenants.
Landlord MUST ensure safety of neighbours is not diminished by tenants.
Disconnecting gas from OUTSIDE does not constitute trespass.
The legal procedure to
get entry, when SAFETY IS NOT AN ISSUE is as above.
Like the average muppet employed by the council, you completely fail to
to realise the essentials here.
You do not need access to a flat to disconnect an outside meter.
By continuously refusing reasonable access requests, the tenant is in breach of the tenancy agreement.
By continuously refusing reasonable access requests, the tenant is actively endangering himself, the neighbours, and property.
What you call: gsr regs, are actually called: gsiu regs; just another example of your lack of knowledge.
And the gsiur are most certainly related to tenancy agreements, as they clearly state that the tenant is held to keep the property safe and and in reasonable state.
I forgot the exact text, but it comes down to: "treat the place as if it were your own."
Not allowing compulsory inspection and necessary maintenance, is not keeping it in a reasonable state, let alone keeping it safe.
