- Joined
- 1 Apr 2016
- Messages
- 13,588
- Reaction score
- 549
- Country
Great you can use Google.
Now search for Prediction vs forecast and understand there is a difference.
https://arielfang.wordpress.com/2008/02/05/difference-between-prediction-and-forecast/
You were the one who was using the term "forecast"....
And, if your argument relies on semantics, you have no argument.
negotiated, any "forecast" would be little better than a guess.
You were the one confusing the meaning. I could guess the weather tomorrow by looking outside or I could use information and weather data and computing to make a weather forecast.
Down the rabbit hole we go.
It looks like you are confusing the difference between forecasting and predicting (which is guesswork).
There was a similar discussion at the analyticbridge website, where several people make various distinctions but none of them seem to agree.
The closest one was, "Forecasting would be a subset of prediction. Any time you predict into the future it is a forecast. All forecasts are predictions, but not all predictions are forecasts, as when you would use regression to explain the relationship between two variables."
So as you say, "forecast" implies time series and future, while "prediction" does not.
Note that there is also a term "projection" which is distinct from forecast or prediction, in some disciplines
In common language one might associate with a forum post, the distinction isnt that obvious.
All forecasts are predictions......
Sorry, Kankerot, but you need to read the bits you select to try and justify your argument, before you post them. At the end of the day, a forecast or a prediction are really just different words to achieve the same unknowable potential result that may, or may not occur.
Forecast – transitive verb.
- 1a: to calculate or predict
Ooh childish and petty at best Kankerot; as well as pot calling the kettle black.
I see the typical Brexiteers needed to get into a discussion on semantics, rather than responding to these non-existent 57 Impact Assessments.
The ones that were in existence for about 12 months, that the PM had read the conclusions, that were supposed to be made available to Parliament, but now do not exist.
http://www.bbc.co.uk/news/uk-politics-42264630
However, I will await the outcome of the investigation.
