Accidental nick to socket cable
Brilliant thanks. I will turn the B32 RCBO off, test the wire using a voltage tester then see if the wire is actually nicked (exposed copper) if the sheath is cut but the live/earth/neutral wires are not then I'll tape over it. If the live/earth/neutral is cut I will then relocate the socket down 8cm. That way no extra joint
Do you mean the copper of the neutral (which has/had blue, conceivably black, insulation) OR the bare copper 'earth' wire?
Probably the neutral copper as I can see (bear in mind the cut is literally 4mm across and less than 1 mm deep) a bit of blue. It's a tiny cut literally a glancing cut from a multi cutter not a full 'go through'
OK. If it's not 'fully through' the blue insulation, you wouldn't be able to see any copper of the neutral.
