Capping Appliances
3 Aug 2006
Hertfordshire
Say you have to disconnect and cap an appliance because it is I.D, but you havent got any caps, what would you do?
Also, how would you cap a back boiler or even a normal wall hung boiler?
Forgot to ask, I want to get all the caps / plugs needed for these situations, which ones and what sizes would I need?
r u taking the ppiss
2nd post tonight , the public are gonna think us RGI`s haven`t got a clue ?
Arf
Scary stuff tonight.
You need iron plugs/caps/compression caps for every conceivable bit of pipework and fitting. Also get caps and sealing discs for gas meters. Get loads of warning labels and warning notices. If you're doing the job properly you'll be disconnecting appliances all the time especially gas fires.
Also get fittings to connect onto any type of fitting with adapters so you can T.T aplliances and pipework with the bellows and manometer connected.
Don't they have an "essential" list of tools/fittings when you leave gas college?
sheesh
how can you go out with out
28mm endfeed caps
22mm endfeed caps
15mm endfeed caps
28mm compression caps
22mm compression caps
15mm compression caps
3/4 male iron
3/4 female iron
1/2 male iron
1/2 female iron
and DEFO some gas meter caps
I have never found the need really
not many appliances on that size steel
try
ww.bes.co.uk
