You appeared to blame it on a fridge.Then you need to look in more detail.
Is there a well-proven insulation material on the market that meets spec and doesn't burn?
No. You tried to blame the fridge.And is that not what I have been saying?
So why don't builders use this?I'm guessing this is too obvious. But isn't Rockwool the alternative?
Probably. And the fact it's not structurally rigid.Is it purely because, mm for mm, it's not as thermally efficient?
It is widely used on new build apartments etc, 150mm thick and Rockwool fire barriers closing cavitys at each floor level and around all reveals, even the DPC and cavity trays are now non combustible.So why don't builders use this?
It's cheaper, so it would cut costs.
If you seriously believe that multiple occupancy building design legislation, stems from "will they/wont they have flammable material/items inside their dwelling" then my insults need some serious tweaking. You must be dumber than I imagined.Carman and Nosey did the fire in the cladding start itself then?
I know.He's just trolling
The only person being shown up is you.Carman and Nosey did the fire in the cladding start itself then? Petty insults are quite amusing and do show you up.
Is there a good alternative to foam based insulation in cladding systems?
I've read you can use Rockwool slabs. But how do they compare in practice?
This is something I wondered about a lot at the time, but never really found the answer.
