Pull cord fused spur - Does such a thing exist?
28 Jul 2012
Surrey
One of family members lives in a council flat, and in the bathroom there is a extractor fan what is always on, what has a pull cord to toggle between the low speed trickle and high speed modes.
Now there is a unswitched fused spur in the corner of the bathroom wall labelled fan, what I assume is for the extractor fan in the bathroom.
I am going to replace it with a switched fused spur for them as they want a way to turn the fan off to save energy, especially when the flat is vacant for weeks at a time.
Just wondering if a fused spur with a pull cord switch built in exists?
Regards: Elliott.
Not that I am aware of. One way to get what you want is to keep the unswitched fused spur and add a normal pull cord but as it is a council flat you will need to get them to do it.
I will just replace the unswicthed fused spur for a switched one then, just like I have replaced light switches for metallic ones in the flat in the past.
Silly as it sounds, could anybody be tempted to use it while in the bath?
123's suggestion is good.
Continuous extract devices typically use less than 5W, in some cases a lot less. Savings for switching it off for a few weeks will be practically nothing, the cost of installing an FCU will never be recovered.
I suppose you have the issue someone could switch it with wet hands, but then you have that issue in kitchens to with sockets near sinks. Maybe the fan may have a switch/jumper inside to disable the continuous low speed mode. Can't remember the make or model of the fan, but the shape of it is a cross between a square and a circle.
The unswitched fused spur is very high up in the corner of the bathroom above the toilet. The sink and enclosed shower are on the other side of the bathroom, there is no bath.
Not when you have a few spare fused spurs in your toolbox. Also poor design IMO of a extractor fan that you can't turn off, i.e. by a isolator or pull switch.
It is proberly correctly designed, to be on all the time to prevent more serious problems like damp and mould occuring
NEVER assume.
Also, if the flat is going to be vacant for weeks at a time, they could just turn the entire circuit off (assuming it's not common with the freezer)
Council house and housing association folk are constantly complaining about damp in their bathrooms.
Your current set-up will have been carefully designed, and no one should be switching it off, only controlled by existing switches and pull cords.
I assume as I have yet to investigate what the un-switched fused spur feeds. Regardless of the purpose and design of the fan being on 24/7, she wants a way of easily turning the fan off.
(0.005kW fan x 0.12P per kWhr) * 24 * 30 = 43P a month to run, or £5.18 a year.
What you are saying there is that in order to save a few quid per year she wants an easy way to turn the fan off even if that wrecks the decor, damages her clothes and furnishings, and risks her health.
Rearrange these words in a well known phrase or saying.
is
mad
barking
she​
Wait, so it looks like this?!?!...
o_Oo_O
I'll get me coat.
Gaz :)
